Stomis
Professional Amateur
So yeah I've got alot of questions about clocking since the ring is sitting in my room now. I'm only going up one notch so my exhaust isnt going to be a problem, just going to use a flex pipe to simplify things.
The next problem that comes to mind would be my skid plate/ crossmember. I'm thinking if I use the stock crossmember and space it up inside the frame perhaps. Any ideas? I'm trying to figure out the easiest way since I have limited resources to a welder. Think I could drill a piece of square stock to work?
Is the actual height of my transfer case where it mounts going to change or just rotate a little? Pictures would be a huge help.
