1-8-4-3-6-5-7-2
Registered Member
1996 K1500 5.7 4L60E with the pushbutton 4x4 (not autotrac)
Hey all, my girlfriend was driving our Suburban and it started making a lot of noise. She pulled off into a lot and called me. It will make a "clunk clunk clunk" noise when driving forward or in reverse, the noise sounds similar to a rear end that's blown up. The Sub has no front driveshaft right now. I unhooked the rear drive shaft and the rear end is fine, so it's the t-case or transmission. I can spin the driveshaft by hand in the forward rotation and it will make clicking noises, but when I try to turn it in reverse it will not turn easily by hand. The noise sounds to be coming from the front of the transmission. The transmission gears will "lock in" just fine, and the fluid appears clean.
Is there anything I can check? Is it likely trash?
Thanks.
Thanks.
