heavy iron
Registered Member
Well found out that 1987 clutch fan for a suburban this 350 is different then one for a 1990 . Bolt pattern is out father and blade angle is different .so what I did is port the hole so it would fit . The fan is so loud and the truck went from running 210 to 250 .put the old one back on went right back to 210 . running a 195 thermostat and put a new OEM fan shroud with the factory 2core radiator. Reading this on the factory temperature gauge. Anyone run colder or is this normal temperature
