clutch linkage
Kuke
Registered Member
Western, PA
I need help trying to find the clutch linkage that goes from the rod on the pedal to the clutch fork. I tried finding it in all the local junkyards with no luck. I tried ebay and craigslist with no luck either. Does anyone know where i can find it??
i am parting out a truck soon. and cleaning out the garage soon. i think i might be able to come up with a set if you dont find one sooner.
Can you be a bit more specific? What year truck. You mention a rod, so I'm gonna assume pre-1984 with al mechanical linkange. Of which there is the rod that goes from the pedal to the z-bar crossshaft, the z-bar crossshaft, then a threaded rod from the z-bar crossshaft to the fork. That is the part one woudl adjust.
Here, LMCTRUCK has what you want, you can also still get this from any GM dealer (that's where I got all those components)
http://www.lmctruck.com
ok it a 78 blazer with a sm465 np 205 from a late 70s k30. i need the z bar crossshaft and the threaded rod from the z bar crosshaft that goes to the fork.
i was digging for other stuff and found the frame bracket/zbar/stud to block/threaded zbar to fork link.
give me your email for info.
Here's a scan of the parts illustration if it helps you. There's a metal bushing and some seals, and that z-bar should be greased every so often. Alot of people overlook it, the metal bushing wears (usally disenigrates and falls out) and you get lots of slop in your setup. I bought all new parts when I put my K5 back together, the seals, bushing, ball, etc...from GM.
yep that pic confirms what i have. a loaded zbar with bracket and lower rod /adjuster.
like i said before give me your email for info on my stuff i dont need.
