COCHEV
So, the small post on the top of the clutch pedal that the MC connects too... can it be pressed out and replaced or at least rotated and pressed back in?
mine has a decent groove worn into it from years of use and it causes unneeded play in the pedal. today, i jimmy-rigged a small peice of plumbers strap in there to take up the slack and it made an improvement in my clutch dissengagement...soooo, i'd like to not be jimmy-rigged forever, i can see that if i could simply rotat it 180 it would fix the probelm. its been a while sense i've had one out so i can't remember if they are welded in there or just pressed in...
not
