I found a set of clutch pedals, I’m not 100% sure that I’ll use them, it had hydro boost brakes, if I were to use them do I need to get anything off the booster? I would want to put a new one on and not reuse old junk. The truck I got the pedal assembly out of had been swapped to standard and they had this goofy link rod down through the floor board, is anyone good enough with these to know if this was originally a hydraulic pedal assembly or is it just a Jerry rigged manual pedal.
