Corey 78K5
1 ton status
Are the pedals the same on both mechanical and hydro clutches, or do I need to look for 85-91 hydro specific ones?
Will do Rene, thanks.Have a set here Corey...and clutch master, line and slave from an '87.
Lemme know if you can't find anything local first.
Whats it involve?The earlier ones can be modded to work with a little effort
Oh hell I can do that. If I can make a 92 Toyota clutch master cylinder work in a 63 Scout then I can make a Chevy part work in a Chevy.I think if you can use a tape measure and a drill you can do the mod. The attachment point for the linkage is in a different location on the pedal. You just need to know what the measurement is.
Yeah just find some fockchop with a measuring tape. Bastard would probably do it in that metric stuff just to piss me off too.Now you just have to find someone to measure it for you... **COUGH**RENE**COUGH**
Whats it involve?
Makes sense. I have to mod the fire wall anyways.I used all factory GM hydro's and a Hydro-bell
But I modified my stock non-hydro pedals to accept the Hydro pushrod, and I added a stop that hits the firewall to prevent over-stroking the master
Yeah, would be chicken sh!t like that.Yes, he probably would do that... even though he would probably measure in inches, then convert it over before sending the info.
