do you need a set, I'm sure I can find a set in a couple different yards...
I need to hit the yard, need some hydro pedals myself, I'll see what I can find...
are you going to make the whole setup ?
or just a swap over pedel and brace rods to add to a mech clutch pedel setup ?
i think the add on setup would be the cat's A$$ in the end .
Isn't there a small difference between vacuum boost and hydroboost pedal assemblies? Or was it just a studs vs. bolts thing? I can't remember.
