COCHEV
About the same amount of bolts to turn. Most all your work is done from topside instead of under the rig, no awkward sm465 to play ballancing act with...
About the same amount of bolts to turn. Most all your work is done from topside instead of under the rig, no awkward sm465 to play ballancing act with...![]()
draining the coolant would be my biggest deterrent from yankin the engine. messy and time consuming.
then there are
fuel lines
electrical
exhaust
hoses
radiator
i can get the engine out of a chev in about 2 hours. i took the trans/t-case out of a burb on the ground, took about an hour and a half, and it had a frozen engine. so getting the convertor bolts out sucked.
either way is a pain with a manual trans. i would rather try lining up the input shaft by jiggling a trans, than rocking a really heavy engine. i hate putting in engines in with a manual trans.
its only 6 bolts and the t-case comes off. seperating them makes it alot easier
Well, I have worked in gravel, dirt, really old falling appart asphalt, and really smooth concrete, and that is why in my last house I had an RV access all concrete leading to a 40x60 pad and I built a 14x21 enclosed Garage, seperate from my 3 car garage for my cars, just so I can work on my trucks.Yeah, I really dislike the fact that I don't have ANY concrete at my current place. It makes simple stuff a lot more difficult. Stuffing the last stick in my burb was a ball buster in the gravel.
I will procrastinate until I find a solution me and my back can can agree on...
It's not ideal, but what about sliding a sheet of plywood under the truck?
Rene
Yeah, it sucks not being 20 anymore...
Rene
I would kill to be 40 something again !Yup, I've seen "20" twice over and then some myself...
Rene
..rather than cut it apart I tried to put it on in one peice using an engine hoist ,pry bars,jacked the truck up off the ground,etc..no dice,the swap bar is right in the way on the passenger side,and it was ALMOST on too!..
..It sucks not being 30 anymore, pretty soon, I won't even be 40![]()
I would chew off my left nut to be 20 again or 30 or 40.Yeah, it sucks not being 20 anymore...
Rene
