Eric1668
Registered Member
Does anyone know where I can get the rubber cup that goes in the clutch reservoir cap? I can find the reservoir or the cap, but neither come with the rubber cup.
Sorry, but something doesn't seem right here. You are saying you cannot find the gasket at all, not even with a new/rebuilt clutch master cylinder? How about posting a pic and a year model?
Well, in that case, your best bet is to get lucky and find one at a dealership.
Is it leaking from the pressure hole (pin hole) in the cap?
I understand now. Mine is folded back like this-
Someone will correct me if im wrong but I believe that cup is only there to keep air from entering your system if fluid gets to low. "I" am not worried about fluid dropping and have no problems with my clutch. If you want to keep yours the way it is perhaps you can clean the diaphragm and use some silicone to fix it. There are probably other applications that use that same reservoir, maybe finding one of those at your pick n pull or dealership would be easy?
*and that diaphragm is keeping the fluid from entering your system when its full. Fold it and it cant "catch it"
No it will not touch the bottom. The dealer wants it to touch the bottom to prevent air from entering if your fluid gets to low. I am personally not worried about the level getting to low, my clutch works perfect. This is just what I did. Again, pull a part will have something you can use even if it means changing reservoirs. Try folding it up, bleed your clutch and see what happens![]()
I'm definitely going to try it. I just didn't want to under fill or overfill the fluid.
Mine is about 3/4's full. It touches at the fold.
