clutch resivor/bracket and line
bww3588
Registered Member
Chillicothe/Lima, Ohio
I need the clutch resivor and bracket. As well as the master to slave hydraulic line for an 89 k5.
Price shipped to 45805.
Thanks guys.
if you cant find one easy try ranger / broncoII / explorer unit . 2 bolts to firewall .
and i just used efi rated fuel hose with the liner on the inside and worked fine .
good luck :thumb:
I found I can buy the reservoir new, for like 8 bucks, but the bracket is un available. I just thought I would try here to see if anyone had the entire setup I could get.
