yep...I'm old!..
I had known about those clutched automatics,just never really did get into the hows and whys of doing that to one...I thought they were cool,kind of strange that you could eliminate the converter,and still have it work!..
I owned at least 4 Chevy's with Powerglide tranny's..a '67 Impala,'68 Caprice Estate Wagon,73 Chevelle,and my 72 Chevelle Wagon all had one..never had a lick of trouble with them,but I hated having only 2 speeds!..my friends ribbed me,saying they had only 2 ranges,"Scream" and "Bog"!!..they made a weird siren noise at idle in park,kinda like a turbo..
GM had another version called a "Turbo-Glide"..I had one friend who owned one, in a '69 Camaro..identical to a Powerglide externally,but it had no automatic shifting provisions--YOU had to shift it manually!..if you didn't shift into "low" at a stoplight,it would take off in "drive",and slip the torque converter to make up for the lack of pulling power...
I think you could only push start the cast iron Powerglides,and maybe some of the early aluminum case ones--they stopped putting rear pumps in them after about 1966???--and NO automatic will push start without one--you cant spin the input shaft with the driveshaft, if no pump is there to push the fluid..
