***SOLD*** Looking to so some mods to the crew cab that will make an compressor setup for onboard air much more suitable. So with some reluctance, I'm selling my CO2 tank, regulator, and mounting bracket.
The tank I bought a little over a year ago from PolyPerformance. I added custom graphics to it (see below). It's a 15lbs tank seen here: http://www.polyperformance.com/Poly-Performance-CO2-Tanks?quantity=1&multi766=40476&multi=1500 I can get several refills of my 37s from 15psi to around 28psi. I included a chart at the bottom with estimated fill-ups for a given tank size versus tire size.
The bracket is from Powertank and it can be locked with a small padlock. http://www.gowarn.com/prodDetail.aspx?partNo=AASBKT-2282
The fixed regulator I bought several years ago from where I can't remember. It's a 125psi fixed regulator. It's a hi-flow model.
I also have a black coiled hose that works great with the CO2 setup.
The only thing you'll need to add to use this is an air chuck. I'm keeping the one I use. Total retail price on all this was over $270.
I would like ***SOLD*** $150 shipped to lower 48. I'm located in northern CO if you'd like to try and make arrangements for in-person transaction.
. Id really like this setup, probably work alot better than my plans for the scuba tank....
