Cobra 18 WX ST II 40 channel CB/antenna
dpmalibu
Trenton,NJ
This is currently in my Suburban and works fine just have no use for it. $40 Located in Hamilton,NJ (Trenton,NJ) (609)481-8811 Here are the features of it:
Scan
Activates scan, all 40 channels
DW (Dual Watch)
Monitors 2 pre-selected channels simultaneously
10 Weather Channels
Receive immediate, up to the minute weather information 24 hours a day
Instant Channel 9 and 19
Instant access to Emergency Channel 9 and 19
SoundTracker System
Activates SoundTracker Noise Reduction System
Last Channel Retention
Saves last channel used in Memory
Heavy-Duty Dynamic
Microphone with 9 For
Cord
Contoured microphone with dynamic voice
response circuitry
Electronic Tuning
Quick, accurate tuning of all 40 CR Channels and 10 Weather Channels
RX Indicator
Indicates receiver is on stand-by
TX Indicator
Shows red when CR is in transmit mode (TX)
WX Indicator
Illuminates when in weather receive mode
4 Pin Screw-On Mic Connector
Convenient removal of mic for storage and easy reach from anywhere inside the vehicle
Power
On/Off and volume control
Squelch Control
Eliminates background noise in the absence of a signal
LED Signal Strength Meter
Indicates incoming signal strength and output power
Front Mounted Speaker
Designed to give you clear reception of incoming calls regardless of installation or ambient noise
Large LED Channel Display
For greater readability
