This truck is stock with the 5.7L TBI engine, L05, and 4L80E tranny. This truck is rust free. I noticed during several previous repairs that somebody had this truck apart for a restoration. For example the Driver's and passenger front seats are reversed. The knob for reclining the front seats is incorrectly on the console side of the seats. The truck will start and run, but rough. I mentioned that it died on me this morning. Nvrenuf is correct this truck has no crank sensor. Part of the recent headaches included repeated sudden deaths resulting in needless distributor replacement, several Ignition Control Module replacements and ECM-B fuses. The problem was worn insulation and missing tubing that resulted in the ECM-B circuit grounding out on the engine and causing the ICM to blow. Much of the wire tubing is now long gone. My thought is that the wiring harness may be the problem. Your thoughts are appreciated. Thanks.
