Can a code 22 (throttle position sensor voltage low) be caused by a bad battery? I just swapped out my battery b/c the other one was bad. It had a code before I swapped batteries but I didn't check to see what code.
Could be a lot of things. Charging system and battery can cause havoc with EFI as they like a steady supply of power and things don't work right out of that range.
Look in stickies and get the TPI pdf, read the codes to see what's there and the pdf will show how to diagnose each code/circuit.
You'll have to run/drive it awhile as when you changed battery's you cleared codes.
There's just so many that use that ECM and differant mask ID. Do you know what year the motor ECM came out of or mask ID of chip?I haven't cleared the code yet, I'm still at work. It's an adjustable tps and when I first installed it I set the tps to within specs and haven't touched it. I parked the truck around October and it ran fine with no codes, then swapped my body on the truck and now it has a code.
My buddy has a modis I tried hooking up to see if I could look at the live data and the vin street and performance told me to use didn't work. At the time I didn't think anything of it b/c it ran fine. You wouldn't happen to no a vin I can put in the modis that it will recognize do you? I'm running a 1227727 ecm
Could be but they usually gook up, hold it pintle side down and flush with brake clean, blow it out and then a light oil. Not with pintle up so moiusture wicks into electronic end.So I think I figured it out. I cleared the code 22 and it didn't come back. Then I took out the IAC and pushed in the solenoid and pulled it back out to free it up. Well it cranked and ran normal. Then I turned off the engine and fired it back up and it was idling high again. Does that mean I need a new IAC?
May have had the DVM on wrong setting, it should read no more than 5 volts on one wire and .54 on another. The wire with .54 should swing smoothly to almost 5 volts WOT.I tried to reset the TPS's location, but when I adjust it the voltage stays the same. Does that mean it's a bad TPS?
Sounds like it. Cross A and B on ALDL port and it should push all the way in.I pulled it out and pushed the button in, then I turned the key on and it moved out. So to me that means it's working, Right?
D'oh!Would you stick with AC Delco when getting a new TPS or does it matter?
Oh, and when I jumpered the A and B it didn't suck the IAC button in, it pushed it out and I had to go searching for it and the spring...
I did that once on my test bench in shop, it's amazing how far they fly...
