code 24......no vss signal
ChickenRammit
FONTUCKY, CA
hey does anybody know how long it takes for this code to set in a '88 TBI system?
i sort of think it should have set a DTC, but it didn't. the speedometer cable was broken inside its housing, and the VSS is driven by the cable.
the truck has some stumbling issues.
i'm wondering if there is a problem with the park/neutral circuit. i think it might be messed up inside the ECM, because the wiring and switch all checks out.
i kind of think that the ECM is always stuck with the p/n circuit in parked mode.
any thoughts?
If the speedo cable is broken then you should pull a VSS code right away.
