I have a TBI 454 in my buggy, the stock wire connector broke that goes from the distributor to the coil. I bought a new harness off eBay, motor wouldn't start. Finally figured out if you hold the connector on the coil end just right it makes connection and starts. I then ordered a harness from painless, same dam problem. Is there a way to fix this problem other than wire tying it? Is there a different style coil that I can use that has terminals that use nuts and ring terminals? Thanks
