73redblaze
I want to get just a little lift on my 2wd c-10. My options are a 2" body lift or using a 2" coil spacer and a 2" block in the rear. No one sells a 2" coil spacer for a 73 c-10 but I'm sure any spacer for that size coil will work right? Thanks in advance
but I suspect that spacing the A-arms down with the coil spacer would necessitate realigning the thing.
was it hard to get the a-arm back on with the coil tight.
