ProfenderUSA
Registered Member
Our 2.0 remote reservoir coilover shocks are used on many applications where a weight bearing shock is needed. These are run on competition buggies all the way through to street driven trucks. These look great and perform even better. They are fully tunable by adjusting shim packs, nitrogen pressure, and spring rates.
We offer many spring rates and sizes so you can choose what is right for your vehicle. Our specially designed piston provides ultimate performance that comes with high precision machining. The polished shafts are chromed and induced which adds more strength to endure all road conditions and heavy duty use.
These are made of the highest quality materials that allows them provide excellent performance.100% QC tested. Aluminum components are all machined to precise tolerances. The Plain Bearing Ball joint is self lubricating and suited for heavy duty and competition use. The hole diameter is ? on both ends, and mounting width is 1.75".
These come with a 1-year warranty against manufacturing defects.
http://profendersuspension.3dcartstores.com/20-Coilovers_c_7.html
