So I'm still contemplating how to route cold air into my dual-input air cleaner on my healthy big block. Jeez, I think it's been in there a year... but I've done all the other stuff, and this project has been kind of waiting on finding an elegant solution.
On my K5, I ran the duct from the air cleaner (just one) to a hole in the core support. Took some hacking and it barely fit. The core support wasn't set up for the ducting (it's a '74; I donno if any that old came with the duct port up front, but this one didn't.)
Regulatory pix:
And yes, it has a grille on it now to block debris.
The truck I'm asking about here is the sixpack in my sig. It doesn't have the duct port either, and since it has the AC condenser and associated plumbing up front (never mind the aux tranny cooler I installed, etc) getting through the core support would be a royal PITA, especially on both sides as there are two intakes. (Which the truck may or may not NEED, but
they're there now so I may as well use 'em.)
I have a spare hood or two, so I debated cutting one up and seeing if I could make some sort of functional induction on it ... but that's a LOT of work, I hate sheetmetal work with a passion, and opening the hood would be a mountain of fiddling with the plumbing. I'm a big fan of KISS -- not the Jon R Pickens variety, well, them too, but the SIMPLE variety. Plus any mods to the hood would block visibility -- a member here used to have that ginormous hood scoop, looked absolutely ridiculous IMHO and left a blind spot in front the size of Rhode Island =))
I suppose I could run the ducts from the air cleaners down below the core support or inside the front bumper or something. It's not a 'wheeler so I won't be playing U-boat Commander in it, but I still worry about water down that low.
The one idea I like, is cutting a hole in the wheel well (inner fender, whatever you call them) for the air duct. It would be a short run, would be easy to plumb and there's not a lot of crap in the way.
The one concern would be water flying up into the ducting, but in the rain, the water should flow off the back of the tire, right, and not go up directly *above* the tire. And as above, obviously I'd put a grille across the intake to filter out debris.
Again, since this thing isn't a 'wheeler (come on, it's 2WD ... it's my tow and utility rig
) I don't see doing a full-on PVC snorkel or the like. This is about getting cold air into the engine so its runs nice, nothing more.
Thoughts or other ideas welcome.
-- A
Regulatory pix:
they're there now so I may as well use 'em.)I have a spare hood or two, so I debated cutting one up and seeing if I could make some sort of functional induction on it ... but that's a LOT of work, I hate sheetmetal work with a passion, and opening the hood would be a mountain of fiddling with the plumbing. I'm a big fan of KISS -- not the Jon R Pickens variety, well, them too, but the SIMPLE variety. Plus any mods to the hood would block visibility -- a member here used to have that ginormous hood scoop, looked absolutely ridiculous IMHO and left a blind spot in front the size of Rhode Island =))
) I don't see doing a full-on PVC snorkel or the like. This is about getting cold air into the engine so its runs nice, nothing more.Thoughts or other ideas welcome.
-- A
Since the damn thing SOUNDS like a muscle car it may as well LOOK like one too, right?
