I assume thats the same as the heavy duty heater, no AC? We are talking non-Suburban, since those could have rear heat/AC.
As far as I've been able to tell, essentially the difference is the fan motor itself. They used the AC fan motor with the shorter squirrel cage of the non-AC setups. The AC motor has a vent hole in it, and the HD heater setup has a like fitting on the heater housing, so that the fan motor will be cooled.
There are other differences, but I'm not sure which is which..some interior portions of the heater box have a "bypass" setting controlled by the cables, some of the heater heads have varying numbers of cables to control the blend doors, and I *think* you get one more fan speed setting on the switch. 4 fan speeds vs. 3?
Is that what you were asking?
