I've even seen a bad CTS not set a code!
I'd never rule out anything and like to hear other peoples problems and solutions. Problem with this being a CTS is I've never seen one do anything but work or go bad/fail and when they do it's -40C all the time. So even warmed up your still running MAX choke. This issue has not mentioned pig rich forever, warm or cold... and he wouldn't be getting 10 MPG, he'd have black soot exhaust, gas contaminated oil... way worse then this little issue.
I understand your theory of it being off and causing this, but have never seen it happen.
How many miles on this rig? TBI still original? You could pop out the plug hiding the throttle blade set screw, this is not an idle screw, it is a minimum air setting. As the TBI wears the throttle blades close. It would not hurt a thing to turn this screw in 1/4 turn. Letting more air past throttle blades helps mix fuel (injector above throttle blade) with air.
Have you checked fuel pressure? As mentioned very important to good running, will run much lower, but not good.
