Collecting parts for motor swap - what motor & trans mounts??
badmix
West Virginia
Eventually im going to need to put a motor in my truck, ive got one readily available and may think about swapping it in, instead of tearing mine apart to fix all the oil leaks.
Anyways, here is a short list of things im looking at;
ORD HD cross member
ORD Transfer case Poly mounts
Poly Motor mounts ??? (not interestd in the ORD racing motor mounts).
Trans mounts ???
1) where to get motor and trans mount
2) Anything else I should be looking at as far as bigger parts.
Motor swap probably wont take place til summer but figure get the parts now as I have the funds and itll motivate me to do it since ill be looking at the parts day in and day out. lol
I'm guessing you're planning on swapping a like engine and not a different style? I will say this either way, make DAMN SURE that your engine and t-case mounts are of the same type (either all urethane, or all rubber) otherwise you'll end up cracking a transmission case in half.
Yea going with a 350 out of an 88 Blazer. Ive got a 305 now.
Ok, I found the Poly motor and trans mounts thru LMC, so ill be all set for that.
