Curious to see how much room I've saved via sinking the column into the dash and going with a smaller wheel.
How about a measurement from the gauge bezel to the column lock plate. Then from the bezel to the 6 o'clock position on the wheel. Stock column set up and if you have the original wheel that would be awesome. 67-72
hmmmmmm, I wonder if going from the top of the rear window to the wheel would be better.....
What's the column lock plate? No stock wheel. I will still give a measurement, whats the lock plate
