79rustyk10
3/4 ton status
http://www.summitracing.com/parts/ESP-B16422LA030/
Im looking at a kit like this for my dd, and Im not sure what to make of the part where it says Piston Head Volume (cc)+5.00cc
The pistons are listed as flat tops with 4 valve reliefs, which should make the chambers smaller due to a stock piston that has a slight dish. I want to keep a stockish compression ratio to keep the EFI happy, and be able to use pump gas.
Is +5.00CC's like subtracting a negative pretty much then? creating a much smaller chamber?
And Scott, anything you know about ford windsor strokers would be of great assistance.
Thanks.
Thanks.
