Compatible hubs
Magikal
North Idaho
I have a d60 from a 1988 dodge w350. It has the old selectro locking hubs. I was wondering if any other modern hubs (warn?) are compatible and can be swapped out?
I always forget the cut off on Dodges, are your hubs internal or external type?
if bolt on = nope your stuck .
if internal = any old hub for 60 work . just match the spline count of the stub shaft 30 stock or 35 upgraded .
if external bolt on only way is to swap to gm /last few year dodge internal wheel/hub units .
