Complete 18' Flatbed Trailer Package
longbedder
3/4 ton status
Staff member
Moderator
Ridgecrest, CA
  • Manufactured by Equipment Pro in 2005
  • 18' flatbed (no dovetail), heavy-duty flip-up ramps with support stands (can drive on/off trailer without being hitched to tow vehicle)
  • 9,000# GVWR
  • Tandem 4500# axles, both with electric brakes (6-lug)
  • 2-5/16" ball hitch
  • 960 miles on Carlisle Radial ST225/75-R15 Tires (load range D, 2012 date codes - installed 17 Nov 2012, have receipt)
  • 960 miles on bearings, grease seals, and Bearing Buddies (installed 18 Nov 2012, have receipt)
  • New decking wood w/ Thompson Water Seal applied
  • All new LED lights and wiring - wiring is 16ga to lights, 14ga to brakes, all crimped/soldered/heatshrunk connections, tinned wire ends in main connector, wires jacketed in split loom and secured to frame with rubber-jacketed steel clamps
  • Removable fenders
  • 12x hard tie-down points on frame (4 on each side, 2 on each end)
  • Stake pockets
  • Top-wind 2000# fold-up jack
  • Clear California title/registration
  • One good spare tire (date code 2009) included
  • Reese 12,000# weight distributing hitch setup with sway damping - trunnions, shank, ball, and everything else included
  • 4x 10,000# ratchet straps included
  • Grease gun with the same grease I used to pack the bearings included
This trailer needs nothing - buy it and start towing. I just revamped the entire thing in order to tow my buddy's '57 Chevy up to Chico over Thanksgiving.
$2300 in Ridgecrest, CA. Can deliver within a reasonable range for fuel money. Would consider a trade for a '78-'79 Ford D60 front.
I'm also selling a Power Caster which can move this thing around. Buy them together for $2950.
Width between wheel wells is 85.5" - it'll fit a D60 with 40" Iroks if you pop the fenders off (4 bolts each side).
Man if I had the cash I would buy this. Great deal indeed.
