Sold Complete Hydraulic SM465 Swap Package-Including Pedals
MAXMAN
Wenatchee,Washington
I have a Hydraulic clutch 32 spline SM465 that comes with everything needed to swap into your project. Includes the SM465, bellhousing, clutch & pressure plate, 454 Flywheel, master and slave cylinders and PEDALS! Everything worked perfect when removed a couple of months ago. 72K original miles, came out of retired 1987 V30 hydroboost brake cab & chassis fire truck. $750
He said nothing about shipping it Mr. Plastigauge!!! Use your suburban as God intended and road trip that beotch!!!
I'm talking another set for the Blazer, I'm not gonna swap the tons out of the K10.
All m1009 blazers have six lug 10 bolts
Gotcha covered! How about the 465 & parts, GM king ping Dana 60 w/dually hubs that can come with a set of SRW hubs and either a narrow or standard 14-bolt full floater for $2600? If interested, depending on how you would want it configured I would have to make sure to match gear ratios as I have a couple of these sets lying around.
