Complete sell off - abandon truck project
NYDIESELDAVE
Penfield, NY
*BEST OFFER BY END OF AUGUST TAKES ALL*
ALSO OPEN TO TRADES.
Well, as many have seen I have been parting out most of the stuff I could from the project and now I'm down to the main stuff of the truck. I have decided to post it here and on craigslist before giving in and paying ebays rediculus fees. Below is a list (that will probably updated as I pull things out that are included in the package. Please bare with me as I will probably have to update it a couple of times.
Now for some info ... the body is a 1985 CUCV that has had the antenna holes and other military mounting accessory holes welded up and body filled. The VERY minor surface rust that is present anywhere's is from it sitting for 8 years in a garage after I started prepping it for primer and paint. The inside of the body has had GM white paint trimmed in. The frame is clean enough to eat off of. I had the body and frame brought up to NY from the south. The rusted doors are on it because I needed doaner doors for the guts of the NEW A/M doors. The axles are currently bolted up under it.
Stuff included with sale:
AXLES / DRIVE SHAFTS:
1985 GMC Dana 44 Front Axle, 3.73 Ratio (6 or 8 Lug) – USED
1983 CHEV Corp 14 Rear Axle, 3.73 Ratio (8 Lug W/Out Drums)
1985 Dana 44 Hubs (6 lug) - USED
2009 U-Bolts (Custom), Dana 44 = Set for 1 Axle w/ Hardware- USED
2009 U-Bolts (Custom), Corp 14 = Set for 1 Axle w/ Hardware- USED
UNK Poison Spider Corp 14 “Rock Ring” – Diff Guard - USED
BODY/INTERIOR:
1985 Cab W/ Military Frame (M1008)
1991 LT & RT Fenders (NEW A/M IN BOX)
1991 LT & RT Doors (NEW A/M IN BOX)
1985 OEM Radiator Support - USED
1985 Tailgate - NOS Military Surplus - USED
1985 Tailgate - (for parts only) - USED
1991 Siding Cap Windows
1985 Front Bucket Seat & Rear Seat (Blue)
1985 ALL Interior Trim for a GMC Jimmy - USED
1985 Military Front & Rear Bump with tow hook mounts and tow hooks.
1985 GMC Grille Dual Headlamp Seat up
1985 GMC Dual Headlamps (LT & RT)
1985 ALL Weather Strips - USED
ENGINE / RELATED:
NONE
STEERING:
1985 Steering Column w/o Tilt w/ cruise
TRANSMISSION
1984 GM NP205 Transfer Case (89k Approx)
1983 GM NP203 Range Box ONLY (Mile Unk), (TH350 Input) – USED =
1983 GM NP203 Input Shaft from TH350- USED
1985 NP208 to 700R4 Adapter Plate- USED
1983 NP205 to TH350 Adapter Plate- USED
WHEELS:
(4) 15 Inch 8 Lug - Chrome Steel Wheels - USED
(4) 15 Inch 6 Lug - Stock GM Wheels - USED
(4) 31-10.50-15 Discovery Tires (Less than 5k)
FUEL TANK:
1985 GM 31 gallon fuel tank with straps - USED
1985 Military Fual Tank Skid Plate (sand blasted and painted black) -USED
ON BOARD AIR:
(1) 2 gallon Air Tank (24"x18") with mounting bracket - USED
(1) York Air Compressor with mount bracket - USED
PICTURE BELOW ARE GROUPED. I HAVE MANY MORE AVAILABLE. IF YOU WOULD LIKE A PICTURE OF CERTAIN ITEM(S) OR SPOTS PLEASE DROP ME A LINE.
Also, anyone that wants to come check it out is welcome. Please feel free to ask any questions. I almost hate to part with the project, but I have fast the fact that I will have it sit in my garage for many years to come before I get to work on it again now that I had kids (twins none the less). My loss in hopefully someone else gain. I would love to see the project to go to someone with the time to spend on it and make a nice rig. Thanks for looking and please pass this listing along if you know of anyone looking in Upstate New york. You won't find one around these parts like it.:waytogo:
I would love to have front seats with mounting brackets pm me
@loafer = Congrats and thanks for the bump. Right now I'm taking offers. So far the best I have is $1,200 for everything.
Well if your willing to sell, or whoever gets it doesnt want em, I'm interested in the seats.
also a random question, any kind of a title with the frame/body?
Good point euzoa. Yes, it's titled and was registered as a 1985 GMC Jimmy with a diesel engine. The title would obviously go with the tub. What Great is based on the title and reg in NY your inspection is emissions exempt for this year because it's a "diesel" and so all you have is a safety inspection.
