CO Complete TBI Serpentine System
I take it these have sold based on how old the posts are? I'm looking for a bracket like your driver's side...The one I got has the alt. tabs at about 120*, I need 180* like the ones you have posted.
I have another one off and ready to ship.
Mine is done...I ended up needing a new alternator and just bought one with a case that matched the bracket I had. Thanks...and anyone needing the stamped steel brackets for a serpentine setup on a 7.4, the ones I took off mine are posted up
Will this work on an older carb'd 350? If so I'll take it.
I can't think of any reason why it wouldn't. Might have to change your water pump also. I will get to boxing it up and get a shipping quote. Thanks
i believe it will, on the older SBC you just need to drill and tap one bolt hole on the head to make it work, and get a new water pump as it will spin opposite direction.
i had one on a 79 block and heads no problem . even skipped the 1 hole that wasnt there .
and yes water pump and fan need to be from tbi engine for reverse flow .
and p/s pump bolts need to match the american or metric threads of the pump your using .
dont forget the t-stat housing is different and the upper rad hose to match . if you use older it trys hard to run in to the alt .
That's a smokin' deal....It's crazy what those setups are selling for elsewhere...I bought my driver's side bracket for more than that!
Let me know the total and I'll send over payment. Thanks Capt Ron
