by the volume, small to big and vice versa..... pressure is always the same thruout a hydro system..
I always like to seperate things into the individual components
So provided there is no way for the fluid and air to swap places in your tank setup and you have your 1 PSI air over an area of 5in^2 you have 5 psi in the exit line of that tank.
Since you have 5 psi leaving that tank you now have converted your 1 psi air to 5 psi fluid.
Now your 1in^2 ram will have 5psi pushing on that ram and thus by default in this example the rod of that ram will exert 5 pounds of push on something.
However, air over hydro is going to make a piss poor setup for steering, the air is too compressible.
So it will work!
This is for suspensiin , not steering btw. And thank you! You reinforced what I was thinking.
So your making an overly complicated air shock?![]()
Just something to keep my mind and hands busy. And not a shock. A spring.
Although... some restrictors and different weight fluids... hmmm
So it will work!
Well, the answer is simple, lets see if I can explain it.........
Use a single tank, no outside lines. Fill it half full of oil, put two pressure gauges in it. One in the air, one in the oil.
Put 10PSI of air pressure in the top. Do you expect the gauge in the oil to have more pressure than the air?
If you can make that work, you have solved the energy crisis...........
Here is your problem. You are confusing Pounds per Square Inch with Pounds.
Take a 10 square inch piston against oil. Put 1 pound of weight on it. You do not get 10 pounds per square inch of oil pressure, you get .1 PSI, because that one pound of pressure is spread out over 10 square inches.
To get 10 PSI, you would have to apply 100 pounds of weight.
With air, you trade volume for pressure. If you put 10 PSI on top instead of an actual weight, you will get your desired 10PSI on the oil, but it will take lots of air volume to do it.
Its hard to explain without diagrams.
But air over hydraulic can act as a reserve source of power for the system, letting the tank act as a spring.
I have been up a long time today, so I am starting to fade. I'll try to be clearer tomorrow.
Ya man. That's **** all, you just need to figure out the ratios and pressure you will need specificly for your weights and application. But if I'm pretty sure I'm understanding what you want to do, it'll work just like our charged struts on the haul trucks. Though I'm not really sure why you wAnt to scratch build hydraulic struts like that. You wanna offroader suspension? Or street cruiser?
Fair enough. They will be hydraulic struts, not air springs, not air struts. Basically the load rides on the oil and the nitrogen is the cushion. For our cat trucks, every service they get drained fully and reset with 7" of new oil, and 475psi nitrogen on top of that, for an overall of around 16"
I was trying to find a way to use a smaller ram and keep a low enough pressure for my oba ssystem.. A 2.5" diameter ram will need close to 200psi in the upper chamber and 80-110 in the lower for sway control.
