Got a motor here I'd like to compression test looking for a bent valve. What should I expect without valves opening? Motor would not run and had a huge lift cam. When he installed it he did not degree the cam or check valve clearance to pistons. I'd like to see what compression says then I think I still have a hose to insert air into cylinders to look for air out intake or exhaust.
