mudbog42
Does anyone know the symptoms of a bad computer chip or how to test them? (86 K-5, 350 w/ Q-jet, and 700r4)
Isn't that the CCC thang?dyeager535 said:Well, you wouldn't have a chip in an '86 unless its the computer controlled Q-jet.
mudbog42 said:it is computer controlled and a california truck
The symptoms is that when it comes to climbing grades the truck has no power. Its got a new jasper 350 and 4:88's in both axles running on 35's and I've also already put in a new ECU. Could it maybe be a bad coil or something?
dyeager535 said:Computer is out of the loop essentially when under hard load/acceleration...only the primaries are controlled via the ECM.
One symptom of a dead ECM is the limp mode, which is full rich on the primaries, all the time. Typically black smoke/soot out the pipes, and horrible gas mileage. (pretty tough to tell that in a truck though lol) In my car though, freeway and city driving netted the same (bad) mileage, which was a good indicator something was wrong.
dyeager535 said:On a CCC carb, key on, engine off, as I recall, you should hear the MC solenoid clattering away in the carb. It may only do this for a few seconds after turning the key, it's been a long time since my CCC setup was running.
