454 blazer
Hey guys , fitted the th350 and four wheel drive train to the big block,and well stripped the clutches , killed the pump , didnt go with a bang tho, just a big puddle under neath.Question : Couple of days after i removed the tranfer case and trans , had the trans completly overhauled new pump etc...Now i bought a 3000stall tourque converter from B&M , ive run the truck for a few days to bed it all in, and it all seems to be running great! the only problem is i have one hell of a leak again
, on closer inspection its coming from were the np205 and the transmission connects .There seems to be a little gap like the bolts at the bottom have come loose, but should there be oil leaking out of this area
??? I thought there would be some sourght of seal there
. Any advice would be appriciated! Still trying to put picks up of the k5,no luck so far, if anybodys intrested then go to you tube and type in 454 blazer , its white with 2 blue stripes.cheers
