If you mean the filler neck hose to the tank,it supposed to be special fuel filler hose thats unfortunately quite costly,it can be up to 25 bucks a foot--its like the hose on a gas pump at a gas station only bigger....you could look for a used one at a salvage yard ,or ,do what I did when I put a flatbed on one truck I had,and use a radaitor hose,which isn't reccomended --the peice I used never leaked or deteriorated,but it did get hard as a rock and you would not be re-using it if it ever had to come off,it would probably have broken into bits..
The smaller 1/2" vent line hose from the tank to filler neck is "special" too,but I have gotten away with heater hose,I just used good quality neoprene hose,dont get the cheap stuff...of course if you can afford the correct factory hose thats the best way to go...
If you wanted to put a return line on your truck instead of just capping it off at the tank,there are metal fuel filters available they used on older Buicks and AMC cars that had a third "return" nipple for a 1/4" hose,in addition to the two 5/16" or 3/8" nipples for fuel supply to the carb.....it was found that having the return line helps prevent vapor lock on carbed engines back in the day,most cars with air conditioning had them..
