Consensus on hydro assist oil
Mudstud
Memphis, TN
Plan on using Mag 1 ISO 32- Light Hydro Oil I found at Northern Tool unless everyone says something different. Hard to beat at $9.00 per gallon.
I have no idea what that is you plan on using but i wouldn't use anything but P/S fluid or ATF (Dexron IV)
I'm running a light hydraulic oil in mine.
Been using Gm power steering fluid in mine full hydro for years.
No issues ever.
ATF is not a good power steering fluid. It is a good substitute but really isn't that great of a fluid for a power steering application.
I am hearing more and more that guys are running a good quality tractor hydro fluid with good success.
No issues ever.
Keep in mind that many of the early GM vehicles spec ATF as the fluid to use.
I understand that but with todays fluids and synthetics, ATF is not really a good power steering fluid. I have been around many vehicles with ATF in them and they work fine, however I have also seen where a system has pumps go out and doesn't work well and then the owner switched to a quality power steering fluid and after getting all of the ATF out their problems went away.
In a pinch I would put just about any oil in my system just to get it off the trail and on trailer. ATF, motor oil whatever.
I have heard good reports on using the Amsoil Tractor Hydrolic oil in full hydro apps. That is what I will use in my full hydro when I finish my buggy.
Harley
