Ok, the '87 project truck for my daughter is slowly getting sorted out, but still has issues. Mainly, it is in need of rebuilt distributor, rebuild for the TBI, and the wiring harness in the engine compartment is a mess with cracked wires running a muck, then it will need to be re-flashed for the '79 350 in it.
Finally, being I have not had this truck on the road and considering how poor the previous owner took care of the mechanical side of things, I really am wondering about the the transmission. I know the motor is decent (because it is mine- his was seized), but will need a ring job in the next 4K miles or so. It holds great oil pressure, but compression is ok.
So, I can get a low mileage '02 5.3, with stand alone ECM, harness, pedal, mounts, radiator with lines, 4L60E (4WD) for around $2400
Then I just need pickup for tank, pump, speedo control and exhaust.
Thoughts?
Thoughts?
