thebird00
I have a huge A/C in my M1010 CUCV ambulance. With the A/C on, the relay for it constantly clicks. Is this normal?
There is a pressure switch that will cause it to cycle on off because it is
1.Low on freon
2.Bad pressure switch
You can jump the 2 wires to see if it will stop cycling,I did this on the old r12 systems when I was doing service to it because it will cycle when adding freon because the gauges would fluctuate.If it is low on freon I would look for leaks.If that's the case they will have to be fixed and the system will have to be evacuated before it's recharged.
I would try to add some r12 if you can get it or it will have to be converted to 134a that will require some other changes to the system to be right.the pressure switch typically looks like this.
Hope it helps!!! Mike
Ok. There was zero coolant in the system. I'm suspecting a leak, but I have picked up 6 cans of Freeze 12. It's supposedly a replacement for R-12. No license required to buy it. Now I just have to get a set of gauges with the right fitting.
I also picked up 8 oz of oil. The guy told me 2 oz should be enough for the whole system.
evacuate the system first,For one you will know if you have a leak.The second is evacuating the system will remove all the air from the system and some contaminates.If this is not done you will most likely have an issue with getting the full amount of freon in the system this is because it will create a vacuum(if you will) to pull in the freon charge.It will pull some in in most cases it wont.Make sure the freon does not have oil added to it if there is to much oil in there it will cause issues.
Mike
How do you evacuate the system?
It just has the large unit for the rear. Nothing up front.
I hit autozone today and rented a vacuum pump and a set of gauges. I bought the conversion kit which is just basically the fittings, 3 cans of 134a and a cheap gauge to fill with.
I could never get my hands on a set of gauges to put the freeze 12 in with.
Thank you for the time you have spent explaining this stuff to me. Your info has been great.
I have 50 oz total of 134a. I should have bought another can or two, but I'll just run back to autozone if it's not enough. Thanks again.
