chevyridinhigh79
I am swapping in a Dana 60 and a 14BFF into my 77 k10 that has a 10 bolt front axle and a 12 bolt rear axle. i got the rear conversion joint number, but i was wondering if the number is the same for front and rear 10 bolts? what size u joints come standard in a heavy half w/ a front 10 bolt... 1330 or 1310? also my rear drive shaft is a lot larger in diameter than most (stock) heavy half rear drive shafts.
