Convert my 10bolt to a 8 lug
trev1981
Manteca, CA
How do i change my 10bolt to an 8 lug or should i just pull one out of a junkyard?
I'm looking for a 14 bolt for the rear.
Should I just pull the front off the same truck?
You can switch axles; if you get them both from the same truck you get matching gear ratios (presumably), which could get you 4.10:1's cheaper/easier than regearing if you now have, say, 3.73:1's. This was my sitch.
Or you can swap the rotors, hubs and all the brake hardware and voila, have 8-lug. You can also steal parts from a D44, as they're the same from the spindles out, and if you get the right D44, might have flat-tops for crossover.
-- A
ya i might just grab both off the same truck, I could use some 4.10s. I have 3.08s i think.
I'm doing 1100rpms at 55mph on OD with 33s
