Convert to TBI or stick with carb?
newyorkin
1 ton status
Los Estados Unitos
I need to swap out the motor on my K20, and the only replacement motors I have are TBI's, '91 and '93 police 350's.
I have to spend $100 and change to get a harness and ECM if I convert to TBI.
Or...
I have to spend $100 and change to get an adapted manifold to put a carb on the TBI motor.
The old motor is suspected of having a bent valve, so the whole motor swap would be pointless if I could just move the heads over, or I might as well just get a valve job done on it for $200 and change without swapping motors at all.
I have to have swap the motors in either case. Carb would obviously be easier and faster to stay with, but I hate carbs.
TBI would probably be a better running/efficient truck. Is it worth the little extra work and then who knows how many little gremlins I'll forget about?
My personal opinion despite some of the problems I've had, go TBI. Once you learn more about the sensors and how they work it isn't that bad. I think going from TBI to a carb is like going from a 4L80E to a TH350.
Less complicated yes, but also a step backward.
Here's a little ranting on the subject of TBI:
If I had a dollar for every cuss word I spoke while working on building my 87 Blazer to where it is now, I could have bought another Blazer in perfect working order. GREMLINS? You want GREMLINS? You can't imagine the *()$% you go through to figure out why the @^$&* wouldn't run right. Replacing $&%^&# sensor after $^&*$# sensor, then it would run like $%#&^)@. Then seeing if it threw a $#&^@ code. And so on and so on............................:mad:
Rant over.
But I wouldn't give it up for anything.
I learned alot about all the sensors (and still learning), from the CK5 family. There is an abundance of help here, and it's priceless. ;)
Go with TBI :thumb:
Went TBI on mine, some issues at first, but nothing a scanner won't find. My biggest issue was an aftermarket cam already installed. Make sure to burn a chip if you do that.
Never had any issues w/ the carb tho, other than it quits running when the tailgate hits the dirt.
wondering that myself
I've got a TBI in my 350, '90 'Burb - but a lot of experience w/the old Quadrajets, and I couldn't help wondering whether a TBI can be as efficient and as flexible as a 2-stage four-barrel? It seems to work, ok, but I wonder whether I'm getting as much out of the engine as I might (or viewed from another perspective, dumping as much gasoline as possible).
I vote for TBI, especially after seeing some of the problems a few of the carbed vehicles had in Moab. Some worked fine, others nope. Most had to alter driving style a bit to contend with the carb.
TBI although maybe not the power you can get out of a good carb on flat ground was priceless. Ho hesitation, no power band, no errattic rpm changes just smooth and consistent.
I knew nothing about TBI when we did the swap, still don't know a lot but don't plan on ever going back to something without fuel injection.
