Converter Bolts
I use blue and torque them to "freakin tight". Red may require heat to remove, and I've never had a problem with blue.
On bolts of any size (i.e. not a 10-32) I've never had trouble removing one with Red Lock-tite in the threads. I'd rather heat the bolt to remove them & risk destroying them than have those particular bolts come loose.
I'll bet you that's because the person before did not clean the threads before applying the stuff. I cleaned the threads on my flexplate bolts and put the stuff on....my impact wouldn't remove them without heat. Try removing a DaimlerChrysler diff from a semi when each bolt has green on it.
That would be me, and I do use something like brake cleaner on both threads. FWIW, no matter how strong the impact I've seen cases where you need to use a breaker bar first. Lock-tite or no Lock-tite. Must be something to do with constant torque vs. impact, I don't know why.
Which Green? There are at least two. One is pretty weak and is or can be used in already assembled fasteners to wick into the assembly.
The other is stronger than Red. One use I know of for this stronger Green is to hold valve guide liners in iron cylinder heads. If it was that Green I'm surprised you got it apart w/o breaking things.
Thanks for the answers guys, I will let you all fight about the color but I'm gonna go with tighter is better :D (and if you like blue don't take that personaly ;) ).
