Converting dual tanks on a TBI to a fuel cell?
2_wacko
Texas
My 87 Truck has the dual side saddle tank but one is not usable its rusted out. I also need new tank straps that bolt to frame. Would it be too much work if I put a large fuel cell and get rid of the side saddle tanks?
Man there's a lot of expensive plumbing down there with dual tanks on TBI. Not only does the switch have to change the fuel feed from one tank to the other, but it also has to change the return line from one tank to the other.
There's a lot of stuff to remove including fuel lines, switches, valves etc... try and get this stuff off un-damaged as lots of guys would like to have it.
Other then that work you just need one feed and one return for the new fuel cell. Best choice for a cell would be with the pump in tank. Now your down to one.
