sschaefer3
Registered Member
I am going to replace the side tank with a Suburban 31 gallon tank where the spare was. The truck has a custom made flat bed so fitting it in and moving it high is not a problem. I have the 6.2 Diesel and it is an 1986 M1008.
I am going to order:
Tank: http://www.mtscompany.com/images/chevygmc/2231a.jpg
Straps: http://www.mtscompany.com/images/strap/GMGTS-31.JPG
Sending Unit for 6.2 Diesel: http://www.mtscompany.com/images/sendingunits/GMSU-31J3.JPG
Do I need this? Or is this just for EFI Gasoline?
Fuel Pump: http://www.mtscompany.com/images/pumps/efpk-3209.jpg
Here are my questions:
1: Do I need that fuel pump or does the 6.2 Diesel engine have a pump on it? Can I lengthen the lines and still have adequate pressure?
2: Does a diesel have a froward and return line line a gasoline engine? Looks like it does.
3: Does this look like I have everything I need to disconnect the side tank and plumb in this rear tank. I can fabricate mounts, that is not a problem.
4: My truck, 1986 M1008 has what appears to be an extremely large filler hole. I sort of want to get ride of this military specific thing and replace it with a standard Chevy part. Is the filler hole that mounts to the bed side the same for unleaded and diesel or are they different sizes?
Thanks this is my first Diesel.
