ciffer
What would I need to do to convert my TBI suburban to a carb?
I have an intake and a stack of Q-Jets.
Stick with the TBI. It'll take mild cams with relative ease. Check out the prom burning section at www.thirdgen.org . Lot's of info on making a TBI/TPI run with big cams.
As for switching, if you must, you'll have to use the electric fuel pump because TBI motors are not equipped with a fuel pump mounting boss. Get a bypass style fuel pressure regulator. You'll have to have a special intake that will work with the vertical center intake bolts. Most aftermarket companies make one that will do the job. Make sure you use a dual plane intake so you maintain your bottom end torque. A HEI distributor will also be needed since you are doing away with computer controls.
