Converting to a Dually?
Pookster
NYC, NY, USA
Someone correct me if Im wrong-
But is the wheels of a dually truck ofset just so, so that the spare would be usable on every axle?
Also, if you used a hub spacer on the front of a SRW truck, and then used a dually wheel on the front- Would that be effectively the same?
[ QUOTE ]
[/ QUOTE ]
They should be, yes. You'll note that the lugs on a dually front are right at or outside the outer edge of the tire; so yes, the wheels have hellish offset when compared to single-tire trucks.
You can get kits to do this aftermarket, however, and some of them are very JC-Whitney-esque and do weird things with spacers and god-only-knows-what. Haven't seen a dually /forums/images/graemlins/k5.gif yet, thankfully, but I've seen several dually /forums/images/graemlins/burb.gif's.
You'll also need to run fairly skinny tires to fit two, even in the extended fenders.
As for
[ QUOTE ]
[/ QUOTE ]
As long as the hub spacer made the track width on your front axle the same as a dually track width, you'd be fine. That's a hell of a spacer though -- hafta be like 4" thick or something.
-- A
[ QUOTE ]
It would actually be closer to a 7" spacer /forums/images/graemlins/thumb.gif
[/ QUOTE ]
Waaaaaaaaaaa! Okay, so my math sucks... it was early in the morning. Still is, actually.
To the original poster: considering that very few people want dually axles, I would think you could find a set CHEAP. You could swap just the outers if you didn't want to do the whole axle, in front. In back I think it'd be easier to swap the whole thing.
-- A
