Hey Guys,
A little background for context before I get into my plans: I just completed a 3 day long off road excursion in Washington, whenever the truck was at 45° angle or more, the carb would starve and the engine would not stay running without gas pedal. If it died I lost PS and PB which made for some hairy backward descents down long technical hill climbs, being a manual made it more tricky, lots of 3 pedals with 2 feet stuff.. Have the Holley Truck Avenger 650 on a Jegs 300hp 350, sm465. The carb probably needs a rebuild and tune, but for the cost of that, to still have starvation issues, I figured I’d consider going to Fuel Injection..
I just bought a barely used MSD atomic EFI, has the TBI, Computer and controller, but I am missing the wide band O2 sensor and fuel pump. The O2 sensor is only $150ish, NBD, however I was shocked to see the fuel pump, filter, line and clamp are $700?!?! And that’s for a return less system, even more for return style.. Now everything I’ve read here and across the web says to run a return style with pump in the tank, so I’m wondering if there’s a lower cost alternative fuel pump option. I see there are EFI conversation tanks with everything you need for $600, but still thinking maybe there’s a cheaper alternative. Is there a different brand fuel pump I can put in my stock 1980 tank? How would I wire that up? I’m trying to balance being a cheap ass with reliability. This is a low priority, so if it’s best to save my lunch money and wait to get the right parts I’m open to that..
TIA!
TIA!
