Cool old ford
dhcomp
1 ton status
Truckee, CA
http://yubasutter.craigslist.org/cto/4764895322.html
1973 Ford F250 Crew Cab Flatebed - $1200 (Marrysville)
image 1
image 1image 2image 3image 4image 5image 6image 7image 8image 9image 10
condition: good
1973 Ford F250 fuel : gas transmission : manual title status : clean cylinders : 8 cylinders
I have owned this truck for 18 yrs an have used it as a welding/ work truck,it originally was a railway truck I built the bed 1/4 diamond plate and tool boxs.
The truck has a Dana 70 rear end, 4 speed gearbox from a 1 ton diesel, it has a 400cid motor 2 brl,carb, new water pump an double roller timing chain/gears "I set the gear at 4deg advance an it needs to be set back to "0".
The truck runs great no smoke, it needs a starter replaced an the timing set back so for the most part it's a solid truck.
craigslist said:
This posting has been deleted by its author.
(The title on the listings page will be removed in just a few minutes.)
Must have sold it already?:dunno:
