Got it out for a test run on the highway to break the gears in... Parked it and noticed it started to spew coolant from the back passenger side of the block area. First I thought it was a core / freeze plug but after pulling the starter it was not. Started it up and the best I can tell is it's coming from up behind the block. My thought now is possibly the intake manifold gasket?? Never delt with this before but it seems like quite a decent leak for just a gasket? I did rule out the hoses and the heater core fitting on the back of the manifold. Could it be possible to dump a lot of coolant from the manifold gasket? I just cant imagine what else this could be. Any thoughts?
My next task will be to get an inspection mirror to see if I can actually isolate the leak. Also I did check that theres no coolant in the oil or oil in the coolant.
Thanks folks!
Thanks folks!
Not at the same time though, but was just saying that both leaked alot.
